1998 V7 Tailgate Strutts Topic is solved
woodycaldercloggs
- Year and Model: v70 1998
- Has thanked: 23 times
Does anyone know if it is OK and safe to install tailgate strutts on a 1998 V70 without using the pins that are supplied. I cannot see any way I can inset these pins once the strutt is installed. ??
- Has thanked: 312 times
- Been thanked: 818 times
The pins are a safety item I would use them.
You can get them on keep trying! Shouldn't be that hard. How did you take the old ones off? Do the opposite thing. Post a pic of the problem maybe we can help you.
woodycaldercloggs
Hi, thanks for your response. Actually the old ones dont have the pin inserted in them - I assume for the same reason but they do seem to be a bit sturdier than the replacement ones.
- 2780 Views
- 3824 Views
Last post by BEJinFbk
- 938 Views
Last post by misha
- 1351 Views
Last post by difflock54
- 23 Replies
- 10990 Views
