Idle tensioner
loveMy850
Year and Model: 1994 850 WAGON
Has thanked: 97 times
Been thanked: 4 times
Post by loveMy850 »
I am not happy.when I went to a shop and had my cam seals and water pump replaced , he replaced my brand new volvo serpentine belt.for no reason!!! Hummm. and didn't tell me! the belt he put on was cheesy and was way too tight, OH I KNOW TRUST ME I KNOW.!๐Ÿ˜ก and it's destroyed my pulley and I'm pretty sure my tensioner spring. I have to replace it. I'm having rough idling and the tensioner is bouncing with a terrible noise and if my timing is off can can I go ahead and replace the idle tensioner and pulley without having the timing checked? There is no one in my town that will touch volvos and the one who did well I already said. But the idle tensioner is so bad I hate driving it until I replace it.
It's only the 2 bolts by the power steering and the pin right. My Haynes doesn't tell. I need my car.... Thank you please. Then I hope I can find some one to check my timing, heck it may not be out of time but I need to put a new tensioner and pulley on. It's all one piece for my 1994 volvo 850.
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Serpentine belt tensioner have nothing to do with timing belt.
It is held with 2 bolts,BUT you need to remove the tension first and slide the serpentine belt from tensioner pulley before you undo those two bolts.
You will need to make a tool for serpentine belt tensioner arm.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1613 times
Been thanked: 4078 times
The serpentine belt and the timing belt are completely separate , so you donโ€™t have to worry about the timing
I recently put on a Conti Belt ona 1998 and it was so tight the tensioner wasnโ€™t needed. Something going on there
manovlov
Has thanked: 675 times
Been thanked: 164 times
Post by manovlov »
It's a child game. You have to replace the serpentine belt and the tensioned. There are severals videos on the web that explains the operation. A couple of tools needed.
Manov
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
There have been some recent reports here of belts that don't fit as intended....
For example:
https://www.matthewsvolvosite.com/forum ... 4&p=552702
loveMy850
Post by loveMy850 »
Yeah I switched it out yesterday, I knew this was going to be a cake walk. It's not making all the noise the pulley was toast and I think probably the tensioner spring was bad where all the noise was. I pulled one out of the JY a few months ago. Finally got to it! Thanks guys
manovlov
Post by manovlov »
cool.
Don't forget to signal "solved" if you don't need any help.
Manov
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
Like manovlov says, indicate solved, and good luck finding a competent Volvo Mechanic, or better yet, in BECOMING one!
Current Volvos:
