New to forum. 05 XC70 235000mi. I picked this up cheap. One cylinder low compression. Burnt valve. Planed head, replaced all valves, pcv box while all apart. NOW- Runs great until you drive it down the road for 10 min, and I get the stop safely no oil pressure message. Sooooo, we flushed the motor, dropped and cleaned oil pan and pickup tube, installed new filter,and Castrol synthetic 10-30. New oil pressure sensor. Same message. The motor runs very quietly, excellent power, and stays quiet after message.
I'm at my wits end. Any ideas?
oil pressure drop
- SuperHerman
- Been thanked: 207 times
vtl's suggestion is solid. Check that out.
You need to check your work specifically the oil pan o-rings. Another question is what type of sealant did you use on the pan and head? Did you use the correct anaerobic sealant or RTV? If the latter that could be the cause as the wrong sealant can cause blockage and/or break away fragments that cause the same.
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
Maybe, pull the oil pressure sensor and tie in a mechanical pressure gauge. It should confirm good or bad.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
- 28 Replies
- 11873 Views
- 524 Views
Last post by matthew1
- 1392 Views
Last post by Salomons Driveway
- 35 Replies
- 17089 Views
- 1415 Views
Last post by tsnyder828
