Replacement Ignition Key
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
Is there any cost effective way to get a replacement key for a P2? I only have the one key and the rubber has deteriorated and is very soft and coming apart. I would like to have 2 keys but don't want to spent hundreds of dollars. Below is a picture showing the condition.
Volvo Key.jpg (92 KiB) Viewed 621 times
2003 XC 70 (sold)
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Has thanked: 7 times
Been thanked: 5 times
Post by Herb Goltz »
The most cost-effective way is to have a new blank cut, then securely affix the one in your picture to the inside of the steering column. That way all you need is a mechanical key, no need for programming.
2012 s60 t5
2006 XC70
2004 XC70
Blacklab467
That sounds like a great idea, Thanks! I wonder if I can carve out the electronic bits or is there a chip or something molded inside that gnarly rubber key handle or should I just glue the whole thing in there?
2003 XC 70 (sold)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
There are three types of keys, first years had this rubber one, then plastic with fob/blade non flippable, last years flippable key fob. I've seen the transponders in all these. In the rubber key I would never try removing it. In the two late ones, it's very fragile inside a thin glass cylinder glued to the fob, very risky to try removing it.
