1998 V70 Headlights Will Not Work When Switch is Turned On
LuckeyMike
Year and Model: 1998 Volvo V70 Base
Has thanked: 2 times
Post by LuckeyMike »
Hi, my 1998 v70s headlights will not work when the light switch is fully switched on. The thing that stumps me is that I can still use high beams and daytime running lights will work. Once I flip my light switch all the way, all outside lights shut off.
I have replaced the switch itself. Is it the fuse?
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Two fuses for low beam, two for high beams. Was in there last weekend with no high beams, turned out I was experiencing a trip to the ride called the "wonderful world of corrosion"
Has thanked: 1610 times
Been thanked: 4069 times
I believe both the DRLs and high beam flash feature bypass the headlight relay, so that points to that.
Try swapping with a used one , they rarely fail.
VOM testing is the definitive way to identify the fault
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
rspi
Post by rspi »
Have you tried turning the key back a little after it has started?
