Riddle me this -fuel filter - transmission '05 XC70
Faust
Year and Model: xc70 2008
Has thanked: 31 times
Been thanked: 10 times
Post by Faust »
For the last few months, my transmission has been shifting (and downshifting) somewhat erratically. I had been waiting for warmer weather to attempt a fluid change. Last week, my fuel filter corroded right through; requiring an immediate replacement. Since replacement of the fuel filter, my transmission behavior has drastically improved. Can anyone see a connection? My "text window" (DIC?) which hasn't worked in recent memory, has also begun operating occasionally .
2004 V70
1964 Plymouth Convert (small block)
1967 Dodge Coronet (big block)
Has thanked: 1611 times
Been thanked: 4072 times
No connection there. Could just be low battery voltage for the rest.
Faust
Post by Faust »
abscate wrote: 22 Jan 2021, 16:54 No connection there. Could just be low battery voltage for the rest.
Didn't touch anything electrical. Only other change is sharply colder weather.
2004 V70
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
fuel filter might have been sucking air a while, causing shift problem due to running lean/lower fuel pressure.
Faust
Post by Faust »
jonesg wrote: 23 Jan 2021, 08:35 fuel filter might have been sucking air a while, causing shift problem due to running lean/lower fuel pressure.
That I thought was a possibility, but wasn't aware of a sensor that might be activated. When my DIC first became activated, it indicated an average mpg of 12.5. This, I assume, resulted from severe leakage through the fuel filter. DIC has currently gone back to sleep and just glows.
2004 V70
Georgeandkira
Year and Model: '07 V70 + '15 XC70
Has thanked: 80 times
Been thanked: 71 times
Post by Georgeandkira »
Extremes in temperature can result in any faulty contact making or breaking.
After reading a bit about batteries lately, I'm all for throwing a charger onto an in-service battery once in a while.
