At least on my '97 850, I would consider the fan running for 3 minutes after the engine is off to be not normal.
Not normal on 850 and s,v,c,xc70 up to '99.
It MUST turn OFF as soon as engine is turned off.
This can happen when ECT or it's wiring are bad or if aftermarket ECT is installed.
ONLY Volvo ECT or at least Vernet.
Volvo ECT is made by Valeo,but you can't find it under Valeo part#.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
After new original gearbox oil replaced, the transmission seem haywire, is that advisable to add in oil treatment ? If yes, which brand is most suitable for this Volvo 850 gearbox.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
I had same problem. It was the fan controller /module attached to radiator. Simple fix in concept, but, tough to get at the small screw. and to seat the module on install. But, it can be done w/ out removing the radiator. Harbor Freight sells a mini/thin screw bit drovwr ratchet, works well. And, You Tube = awesome !
2008 Volvo XC70.
