So, I'm finally able to get back to reassembling this replacement trans for the wife's car, and I'm now questioning what is used to seal the case back together.
I know for the solenoid/valvebody cover, Aisin AB1281B is used, but what about the rest? What came off kind of looked like the "pink stuff" used on the engine mating surfaces. Is that correct?
AW50-42LE case sealant?
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
- RickHaleParker
- Been thanked: 958 times
Permatex 81180 RTV Gasket maker.
Don't over do it like a lot of people do. It is for filling the imperfections not glueing the case together.
- Chuck W
So, not the 51813 anaerobic stuff? The 81180 is listed for "transmissions", but I've seen the 51813, or Volvo pink stuff mentioned.RickHaleParker wrote: ↑24 Apr 2021, 16:22 Permatex 81180 RTV Gasket maker.
The stuff on the current case looks like the Volvo pink stuff, and not RTV.
- Chuck W
Any other thoughts?
I got busy over the rest of the weekend and didn't get back to working on this, but I'm wanting to get moving forward on it.
I have some of the Permatex anaerobic stuff(51813) on-hand (from when I did work on our engines), so I may just use that and move on.
- kallekula
- Year and Model: S70 2000
- Has thanked: 58 times
- Been thanked: 75 times
That stuff will probably work as well, I just want to minimize any problems having to redo it all. Therefore I use the pink stuff for both motor and transmission. Good luck!
BMW 540i 2002
S70 Base 2000
- Chuck W
The Permatex stuff is the same thing as the pink stuff. I've used both with good results.
- Chuck W
It was the concern about the compatibility with ATF, but that may not be an issue in the "case" of sealing the trans case.
I know there is more chance of contact with the "pan" cover, and there is a special Aisin RTV for that (which is probably what the Permatex 81180 is similar to)
Just trying to get some input from folks who have done it, but it doesn't sound like many around here have. It's not something I want to have to do twice.
- 893 Views
Last post by Turbonic77
- 1450 Views
Last post by wheelsup
