No horn no audio controls on the steering wheel. Topic is solved
cmbfoto
- Year and Model: 99 S80 02 XC70
- Has thanked: 11 times
After replacing the lower steering coupler that was a challenge now the soft controls on the steering wheel (airbag) dont work. This includes the horn and audio buttons. I did lock the steering wheel in place but my assistant might have turned the wheel when I was grabbing a cold snack. Just Great..
leapdragon
- Year and Model: 2007 XC70
- Has thanked: 12 times
- Been thanked: 31 times
With luck maybe some wires/connectors just got pulled out behind the airbag. Find a video on replacing the steering angle sensor, it'll show you the lay of the land behind the airbag including the connectors for those controls and horn that are oriented such that they could well have been pulled out by accident.
If you're in the right mood and also have a T25 on hand, it's maybe a 20 minute job to get all of that apart and gain access to the cables, either to reconnect if disconnected or to do some testing with a meter and try to diagnose which may be affected by a broken wire somewhere.
- 1414 Views
Last post by vtl
- 657 Views
- 1281 Views
Last post by Ou2mame
- 7064 Views
Last post by kranz
- 25837 Views
Last post by Lemonade455
