Error code P0171 and P0172
shayinok
Year and Model: S70 1998 T-5
Has thanked: 1 time
Post by shayinok »
So my 1998 S70 T5 lost boost on the highway and threw both the P0171 and P0172 codes. I replaced the MAF a few weeks ago due to some stuttering symptoms at idle. Ideas on where to start my search on the cause?
Thanks!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Those codes are usually pointing to a vacuum leak.
One is lean and the other rich condition.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
EricVolvo850
Year and Model: 1996 850
Post by EricVolvo850 »
P0172 system rich mixture
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Here are diagrams of the vacuum system https://www.matthewsvolvosite.com/vacuu ... 00-turbos/
Also -> Amazon link
RickHaleParker
Been thanked: 978 times
Post by RickHaleParker »
Long term fuel trim, lower limit ( Too Lean, P0171 ) and long term fuel trim, upper limit ( Too rich, P0172 ).
One thing common to both DTCs is Mass Air Flow (MAF) sensor. Clean the Mass Air Flow sensor, check wiring and voltages. If none of them are the problem, replace the MAF sensor.
Cleaning the MAF sensor should be on your preventive maintenance list. Not a repair. A can of MAF cleaner will pay for itself in terms of improved fuel economy.
Active
Past
matthew1
Site Admin
Post by matthew1 »
Here's my P0172 experience on my 850 T-5.
Click that for a closeup photo of the vacuum line that blew off.
Also -> Amazon link
