'93 10v 850 auto wagon is the beast in question.
Riddle me this one
Drove to the local shops the other day no problems until I restarted the car to go home, engine started and ran ok but the ABS and SRS lights came on and I had no other power whatsoever, blinkers, fans, windows, radio, nothing at all. it wouldnt go in anything other than a forward gear, drove home ok, changed gear no probs etc. but electrically nothing still worked, Turned it off and restarted it ok and it hasn't missed a beat since, have they got a main electrical relay for other things but the ignition system that maybe got stuck open or shut ???, or has anyone struck this before.
- Has thanked: 17 times
- Been thanked: 35 times
Very strange....electrical glitches are some of the hardest things to problem-solve on these cars. Maybe a battery that is low and by you driving it home, charged it just enough to remedy the issues....that or poor connection to the wiring- often ground wires and/or positive battery post wiring could cause some strange things.
JRL
- Year and Model: Several
- Been thanked: 16 times
You need a new ignition key lock assy, they go bad and short out the entire carcocka wrote:Drove to the local shops the other day no problems until I restarted the car to go home, engine started and ran ok but the ABS and SRS lights came on and I had no other power whatsoever, blinkers, fans, windows, radio, nothing at all. it wouldnt go in anything other than a forward gear, drove home ok, changed gear no probs etc. but electrically nothing still worked, Turned it off and restarted it ok and it hasn't missed a beat since, have they got a main electrical relay for other things but the ignition system that maybe got stuck open or shut ???, or has anyone struck this before.
'93 10v 850 auto wagon is the beast in question.![]()
DVolvoguy777
- Year and Model:
+1 with the above folks. What they said.
You may want to check the condition of your battery terminals. If they are corroded they could do the same thing. I would clean them with baking soda and run some dilectric grease around the terminals for chits and giggles just to be safe.
I am a current Volvo 850T5 owner. Have had '67 144ES, 71 142E, 76 245DL, 80 242GT, 81 245DL. Still wish that I had the 142E.
I scored an '06 Harley Dyna Superglide for Fathers day.
Thanks for the replies people, I had a new key cut when I first got the car I'm using it at the moment and it's a lot tighter in the barrel, I'll persevere with that for while and give all the earth connections etc. a good once over, can't hurt, still working ok for now
JRL and others are right on... but it is actually the electrical part of the ignition switch that fails. This part is available seperately from the entire lock assembly, and can be fixed in situ by just dropping the panel... and with some patience you can remove and replace those screws that hold it on. Your new key won't fix your problem.
Thanks for that, I'll do some sniffing around to see if I can source a new one at the right price even if I don't fit it but keep it as a spare for the future as it seems ok for now.cn2000 wrote:JRL and others are right on... but it is actually the electrical part of the ignition switch that fails. This part is available seperately from the entire lock assembly, and can be fixed in situ by just dropping the panel... and with some patience you can remove and replace those screws that hold it on. Your new key won't fix your problem.
- 868 Views
Last post by Georgeandkira
- 245 Views
Last post by deano1
- 605 Views
Last post by treestone27
- 1898 Views
Last post by FCPEURO
- 1639 Views
