Volvo MAP Connector 30658215 Topic is solved
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
truenorth
Year and Model: 2011XC70
Been thanked: 8 times
Post by truenorth »
I recently removed my XC70 intake manifold to replace the thermostat, everything went well except I couldn't re-attach the MAP connector back to the MAP sensor 8699339 (Denso 6G9N-9F479-AA) thinking that I broke the connector lock.
After going about the long way to replace the connector 30658215 which is a delicate job it turned out my connector wasn't broken. The root cause why I couldn't re-attach the connector is because at the base of the connector the silicon stopper expanded over time and it was preventing the connector to re-latch to the MAP sensor (even with considerable force applied). See pic 2.
If you run into similar situation like I did, a simpler solution (assuming you didn't break the connector tab) is to trim a little bit of silicon stopper inside the connector where the MAP sensor connector come in contact (Pic 3) with a sniper from the side. If it still doesn't work, you can remove the entire silicon stopper and trim further. I have included some pictures so you can see what I mean. Word of caution, this job is best if you have small hands and arms :D and I did it from the top of engine bay, otherwise you have to get at it from the bottom of engine bay.
connector with blue silicone stopper. Pic 6
removing the connector guide. Pic 5
removing the connector guide. Pic 4
expanded blue silicone stopper  preventing connector to latch. Pic 3
MAP sensor and MAP connector coming together. Pic 2
MAP sensor and MAP connector coming together. Pic 1
3Bixbyboys
Year and Model: 1998 V70 Base
Post by 3Bixbyboys »
My connector is broken, have ordered new housing but need to know how do you remove the pins to be able to insert them into the new housing?
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
Remove the white part and then use the pin release tool.
Then the terminal can be pulled straight out
Good luck
Paul
3Bixbyboys
Thanks! I ordered a set of extraction tools, see if I can figure this out.
skousend
Year and Model: 2009 S80
Has thanked: 1 time
Post by skousend »
This was a very helpful post. I needed it to understand why my MAP sensor replacement wouldn't "take". Rather than disassemble and trim, I fixed it by using a toothpick to put a thin layer of plumbers silicon grease on the edge of th blue silicon piece. This allowed the sensor edge to work it's way over the boundary and seat.
COvolvo2009
Year and Model: 2009 XC70
Has thanked: 2 times
Post by COvolvo2009 »
Also found this post very helpful. To echo skousend, the grease idea worked! I have a 2009 XC70 and accessed the connector from underneath the engine bay. Applied a small bit of grease to the blue silicone piece and to the edge of the map sensor receptacle. The two snapped together on the first attempt with minimal force. I was about to go down the same route as OP replacing the connector but Im glad I stumbled upon this post first.
