What do I need for 'drain and fill'?
AlanS
Been thanked: 2 times
Post by AlanS »
I'm gathering my supplies for a 'drain and fill' on my wife's 2013 S60. A friend gave me 5 qts of Mobil 3309. Is this the correct trans fluid to use? Is it fully compatible with whatever fluid remains in the gearbox? If so, then I guess I will have to pick up more. How much fluid usually exits on a typical drain?
I am also trying to get some washers for the drain plug. Seems that there are 'choices'. Metal, and then there is a thick O-ring offered. What do I need for a drain and fill?
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
There is a nice video tutorial in this post and some additional helpful instructions:
viewtopic.php?f=26&t=94671&p=549490&hil ... on#p549490
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 120 times
Been thanked: 189 times
Post by pgill »
Alan,
It is likely that you won't get quite this much out. But it will be close.
If you can't tell from the picture I was able to remove 3.8 Quarts
AISIN switched from the
T-IV type fluid (JWS 3309 (T-IV)
to the
WS type fluid JWS 3324 (WS)
And they did it around the time that you are asking about
Note: my research indicates that the fluids can be mixed but for me I prefer to stick with the original fluid.
For my Son's 2015 VW I used the WS fluid and for my other Son's 2010 Volvo I used the T-IV type
Parts to get
30713219 Auto Trans T40 Bolt
1233068 O-ring for T40 Bolt
30713220 Washer
https://www.fcpeuro.com/products/volvo- ... 0-30713219
https://www.fcpeuro.com/products/volvo- ... 90-1233068
https://www.fcpeuro.com/products/volvo- ... 0-30713220
Good Luck
Paul
PS Looking at IPD it looks like you need the WS not the T-IV
https://www.ipdusa.com/products/10543/A ... 540-122082
https://www.ipdusa.com/products/10578/A ... 774-123941
