Now that I have completely drained the coolant (replaced water pump also).
For my two 2001 XCs, I have been using the green coolant. I have other cars I use different coolants in them. I currently have about four or five coolant colors. Can I use the universal (All Models) in these volvo?
Thanks
Universal (All Makes And Models) Coolant In Volvo? Topic is solved
Oka
- Year and Model: XC70, 2001
- Has thanked: 9 times
- Been thanked: 4 times
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 45 times
I'd recommend against it.
I have only used Volvo green in my 2001 V70 T5. Never had a leak, or any cooling system problem. Maybe replaced the thermostat and temperature sensor once in 20 years. I'm sold on the Volvo formula. I believe a gallon is less than $30.
Why change now?
Why change now?
Oka
Thanks for your thoughts on the coolant. The green coolant I use is not Volvo coolant. It’s store bought coolant. Guess I’ll stick with it.93SCMax wrote: 10 Oct 2021, 06:30 I'd recommend against it.
Why change now?
Cheers
- Been thanked: 504 times
I have used only Green Prestone (the fully concentrated version) + distilled water for the last 25 yrs
on my BMWs, Volvos.
Zero issues.
In fact, when I opened up the thermostat housing, WP areas etc., the inside of the engine looked pristine clean.
I like Prestone...
on my BMWs, Volvos.
Zero issues.
I like Prestone...
Oka
I’ll just stick to the “green” coolant.cn90 wrote: 10 Oct 2021, 11:37 I have used only Green Prestone (the fully concentrated version) + distilled water for the last 25 yrs
on my BMWs, Volvos.
Zero issues.
I like Prestone...
Thanks.
- Has thanked: 987 times
- Been thanked: 1075 times
Zerex G-05 is labeled for modern Volvo use. I have used for many years.
