Carbon box 95 850 N/A
Danonly55
Year and Model: 1996 850 sedan
Has thanked: 23 times
Been thanked: 4 times
Post by Danonly55 »
What would happen mechanicly if my carbon box and fuel tank vent were not connected ?
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
Has thanked: 1502 times
Been thanked: 3817 times
You are going to Vent gas fumes into Mother Nature and she will angrily set a code for an evap error in retaliation
foggydogg
Has thanked: 83 times
Been thanked: 402 times
Post by foggydogg »
Better than even odds that it will disconnect itself naturally, then you get to play Whacka-Mole-vacuum hose.
Danonly55
Post by Danonly55 »
Ok , don't want to piss off mother nature. The car came with a replacement carbon box, purge line not hooked up or vent from tank not hooked up. No codes at all. It also passed emmissions :o . The car does have all new vacuum lines instaled when I did the PCV system. It still doesent have much pickup when I have to slow down on the freeway and then get back up to speed... slow to get back up to speed, she's a dog/pig/snail. Any Ideas guys ??
" John Wayne
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
Maybe she hangs out with Shotzie the Diesel Mercedes too much? :lol:
Assume it has had routine maintenance? Plugs, wires, etc.
badboye46
Year and Model: 1994 850/91 240
Been thanked: 2 times
Post by badboye46 »
I know this is an old post, but I have a 94 NA sedan and have found that there may be the same problem with my car, my charcoal canister is connected and recently after having the same problems you are describing I found a missing plug (or vacuum cap) missing on my canister, the car idles fine runs fine once I get up to speed. But that’s where it sounds a lot like your problem. There is a vacuum line connected to the top of your air cleaner box top held on by two screws, one vacuum goes to the vacuum tree on the intake and another on that piece is teed and goes to the charcoal canister, these lines connect right under the battery tray. So if you are running the existing charcoal canister; as you said you have a spare, and the fuel vent line is disconnected and other lines to the vacuum canister, that is now a vacuum leak and could explain the “no pep” issues with your car should you still own it.
