Can someone please assist with a detailed Thermostat replacement procedure for my 2000 S80 2.9 (non-turbo). I know where it is located but I would like some experienced advise so I am sucessful. (ie: any tricks of the trade, special tools, step by step procedure, cautions,draining coolant, etc.
Getting cold feet in the middle of the winter (NE U.S.A.) - thermostat must be stuck partially open.
All advise is very much appreciated!
Thermostat replacement procedure 2000 S80 2.9
Cyberwilbur
- Year and Model:
- Has thanked: 17 times
- Been thanked: 35 times
Not sure how your car is set up but if you have the expansion tank above the thermostat, drain it out or siphon out so that you don't loose much coolant. When you open the thermostat housing, have a towel wrapped all under it...this will catch what comes out and keeps you from having to drain any coolant (which is a pain). After you change the thermostat, then refill everything. It is easy on both of our cars.
Cyberwilbur
- Year and Model:
Does anyone have any specific thermostat replacement experience with a 2000 S80? How to!
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Depends on which engine is fitted as to how the thermostat is replaced.
B6284T; B6294S; B5244S.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Cyberwilbur
- Year and Model:
PLEASE ASSIST ME!
This is a 2000 S80 2.9 litre (non-turbo) with a B6294S engine.
Thank you in advance. Awaiting a detaied reply.
- billofdurham
Previously:
Previously:
- 496 Views
Last post by Skymongrel
- 797 Views
Last post by rmmagow
