1994 Volvo 850
mataman69361
- Year and Model: 1994 850
1994 Volvo 850
I was wondering if anyone knows if I can put a motor from a 1995 850 turbo wagon into a 1994 850 non turbo wagon?If so how difficult would it be and what would be involved? Any help would be greatly appreciated.
- Has thanked: 1511 times
- Been thanked: 3829 times
The motor will bolt in fine , you will have to make sure you get all the accessories
Air filter, snorkel, evap and intercooler are all different or missing
You need a boost valve and hoses.
Finally, your ECU will need to be swapped or tuned to drive the turbo.
- Has thanked: 294 times
- Been thanked: 767 times
Extremely difficult.
Also exhaust manifold and downpipe are different. Basically swap all the big pieces between the muffler and the radiator. The little ones will mostly move over from a 94.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Sveedy
- Has thanked: 418 times
- Been thanked: 457 times
My understanding is that this swap is not really doable. All of the wiring in the engine compartment has to be switched out with the turbo harness. Lots of write-ups on it if you research a bit.
1999 V70 GLT
1999 V70 GLT
- RickHaleParker
- Been thanked: 958 times
Does he want to convert his NA to turbo or just use the turbo engine as a NA replacement?
The latter would be easy, just use the NA ECM, TCM, wiring and plumbing. It would have lower compression and less power for a NA but it will run.
Yes you can drop in the 2.3 engine but *I am told* it is not a viable replacement. So much less power as to be undriveable.
Somebody do one and tell us about it!
'06 S60 R, 197k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- RickHaleParker
Must of the time a Turbo charged car is operating as a NA. I would think it would run like a Turbo charged car until you punch it hard enough that the Turbo would spool up, if there was a Turbo to spool up.
The lower compression would let one run the cheapest gas.
- 576 Views
Last post by precopster
- 1211 Views
Last post by rubyvette
