ipd plate
magna224
- Year and Model: 850 T5's
- Been thanked: 3 times
ipd plate
Does the ipd plate add any rigidity or does it just flex? My cars on ipd blue springs and koni yellows so i know its very protective at this point but my car is someday intended to be mostly track oriented and im interested if its worth the weight. I have one in the garage but ive never installed it, id like to know other users experiences.
Volvo 855 T5 1995
Volvo 854 T5 1996
Toyota MR2 1987
Volvo 854 T5 1996
Toyota MR2 1987
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 96 times
- Been thanked: 333 times
The ipd skid plate isn't structural at all.
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
magna224 wrote: ↑26 Jan 2022, 17:53 Does the ipd plate add any rigidity or does it just flex? My cars on ipd blue springs and koni yellows so i know its very protective at this point but my car is someday intended to be mostly track oriented and im interested if its worth the weight. I have one in the garage but ive never installed it, id like to know other users experiences.
Perhaps the weight will be offset by the aerodynamics
- Has thanked: 292 times
- Been thanked: 765 times
Huh?
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1497 times
- Been thanked: 3810 times
Is there a matching cup and saucer ??
- Has thanked: 1836 times
- Been thanked: 1709 times
I would disagree on that fitting this plate would not stiffen things up. If it is bolted to the sub-frame then it will stiffen that up somewhat as if I recall correctly it is a pretty stout item. However, it will only stiffen up the sub-frame. You are then dependent on the condition of the sub-frame to frame mounts. If you replace those with poly versions and and a strut brace it would increase the front end stiffness. You could add IPD's sway-bars, or at least one from a V70XC which is the thickest version they made of standard P80.
By itself, it is mostly a engine oil pan guard!
- Chuck W
It's bolted with rubber isolators and just wedged into slots on the subframe, IIRC. Mine didn't come with the hardware (got it out of the yard), but looking at the ipd install instructions, it isn't a solid mount.
The Delrin SF bushings and the STBs I built did more to stiffen things up than this thing would. It's mainly to act as protection to the oil pan, etc.
- 1407 Views
Last post by RayF
- 583 Views
Last post by stephansvolvo
