Windshield washer check valve?
454cid
Year and Model: 1996 850
Has thanked: 145 times
Been thanked: 129 times
Post by 454cid »
I have to run my washer pump longer than I'd expect to get any washer fluid on the windshield. I did find a video of a man replacing check valves, but they were directly under the nozzles and on a newer Volvo. I'm thinking there should be one closer to the pump so the line doesn't have to fill up on every use. Is there supposed to be one there from the factory? In the pump maybe?
Also, do 850's really spray two solid streams per side, or do I have partially plugged nozzles?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Has thanked: 1504 times
Been thanked: 3817 times
People often replace them with knockoffs that are single stream ,or they plug
Of you really want to class the neighborhood, show off your fan shaped 1999 w/w nozzles…part number 30655605
454cid
Post by 454cid »
abscate wrote: 03 Feb 2022, 01:32 Of you really want to class the neighborhood, show off your fan shaped 1999 w/w nozzles…part number 30655605
That sounds like what I need, Thank you!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 24 times
Post by befarrer »
On my 98, the check valves are directly under the washer nozzles under the hood, there are 2.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
Year and Model: 2001 V70
Has thanked: 927 times
Been thanked: 1000 times
Post by volvolugnut »
454cid,
I like the way you are systematically checking and upgrading your recent purchase.
454cid
Post by 454cid »
volvolugnut wrote: 03 Feb 2022, 11:53 454cid,
Lol, thanks. It's mostly about what bothers me next :lol:
That, and this process is kinda fun.... although, I admit, I was a bit stressed over the timing belt.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
I purchased the ProPart version of the newer washer nozzle. I just got them installed, which was very easy.... I just used a stout pair of needle nose pliers to remove the hoses, and then squeeze the plastic nubs and the original nozzles came right out.
Unfortunately, the new nozzles are a disappointment. I'm not sure if it's the part, or if it's a pressure issue. They don't have a nice spray pattern, and they don't hit far enough up the windshield. They "function", so I'll leave them in place for the moment, while I figure out what I want to do next.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
454cid
Post by 454cid »
I found that there is a check valve listed for my truck, and I'm planning on getting one for the 850. I'll mount it near the pump, so lines don't have to fill up each time I want to wash the windshield.
https://www.rockauto.com/en/moreinfo.ph ... 1096&jsn=6
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
Has thanked: 1847 times
Been thanked: 1710 times
There has to be another check valve somewhere in the system nearer the spray nozzles. On my V70 '00 the water starts almost immediately.
There are 2 check valves near the headlights but those are for the headlight washers. Those are little diaphragm valves and the rubber diaphragm either splits or sticks open when it fails which also reduces the water pressure to you windshield as the water drains to the ground. If you are careful you can open the units and check if they are just dirty or blocked.
https://www.amazon.com/Volvo-31391513-T ... B00W4DTN2C
https://www.ebay.com/itm/392882977639?_ ... 101224.m-1
Wagons also have one near the RH hood hinge for the rear washer on the tailgate.
I though there was another one in the hood area for the front windshield.
https://www.ebay.com/itm/294437470102
454cid
Post by 454cid »
scot850 wrote: 10 Feb 2022, 14:04 There has to be another check valve somewhere in the system nearer the spray nozzles. On my V70 '00 the water starts almost immediately.
I have not laid eyes on them, but I know there is supposed to be check valves near the nozzles I assume they're under the hood insulation. I don't really understand that placement as they would not prevent the long line from the pump from draining, which is what I think is happening to mine. My thought is that the pump itself may have a check valve internally that has failed.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
