So I'm wondering if there is a significant amount of oil in the block that I should be accounting for with a fresh rebuild.
I put 6 qts in originally ( Amsoil Break in oil ) , and it seems a little low on the dipstick. Not too much, but maybe 1/2 qt.
Just being paranoid ? I should say that I had problems with the dipstick in the past ( broke the handle off ) so the handle has been re-glued on a couple of times.
Oil capacity of rebuilt engine Topic is solved
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Same stick, tube. New O-ring. I had the stick and tube while block was in the shop.
Researching it more, it might be normal, at least according to a Google search for engines in general.. For what that's worth.
I'll top it off a little just to be safe.
1999 V70 GLT
1999 V70 GLT
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
The fill for the turbo motors is 6.1 qts.
What motor are you using again?
- Chuck W
On an oil change, I use 6.1 qts. They say 5.6 qts "without oil cooler" and the capacity of the cooler/lines is just under 1 qts (0.95 qts)
If everything is dry (as in the oil cooler,lines,etc was also drained) you're looking at closer to 6.5 qts to get to capacity.
- Sveedy
So if there is some issue with the stick / tube, then I could put in 7 qts total, drain and then add 6 qts back. That should get me right. Then deal with the stick.
1999 V70 GLT
1999 V70 GLT
- Chuck W
I wouldn't worry about the dipstick.
If things are dry, put in 6.5 qts. Let the car run for a couple minutes, then stop and recheck the oil level after it's sat for a few. That should show you your "full" level. Then after that, gauge your 6.1 qts fills at oil changes and see how they compare. If you have 6 qts in there now, just add a little more and let it ride. It's not going to hurt anything.
If it's a fresh engine rebuild, you're going to be draining it soon-ish anyway.
If you're one of those people who need to have it at the "MAX" line, I doubt extra little bit over 6.1 qts needed to reach that will cause much issue, however.
My '97 N motor is running a P2R oil pan/cooler and I needed to swap dipsticks, as the P2 one is longer. Before I swapped the dipstick, my 6.1 qts was only registering on the lower 3/8-1/2" of it. It still doesn't run at "MAX", but I'm not worried about it.
- Sveedy
Yes I'll be doing the first drain @ 5oo miles. And I'm still running my catch can w/ filter, so it's not a closed system anyway.
Don't think a few ounces in that case could cause any problems.
1999 V70 GLT
1999 V70 GLT
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
My owner's manual says 5.6 quarts, and 6.1 quarts for "certain models" and to add .95 quarts to turbo models if the oil cooler has been drained.
I guess my NA 850 is "certain models" because I put about 6.5qts in it. The stick goes in at an angle, so one side is right at the max, and the other is slightly higher.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- 2329 Views
Last post by BlackThunder
- 3560 Views
Last post by donc
- 329 Views
Last post by magna224
- 2032 Views
- 12 Replies
- 3473 Views
Last post by misha
