96 850 R turbo break up
Flametrap666
Year and Model: 96 850 R
Post by Flametrap666 »
I just purchased a 96 850 R.. when I dump the throttle and it pulls boost it hits about 4k bogs down and back fires.. check engine flashes due to the car misfiring on more than one cylinder. Its running a tune but I don't recall the brand as the car is 2 days new to me. I find it hard to believe it's related to the tune and feel as if something a little more sinister is happening. I've owned a lot of Volvos over the years but have never owned something with a tune and high pressure turbo. Please help with any possibilities of why this could be happening. I'm only looking for experienced people to respond as we know unfortunately lots of "Parrots" exist on these sites. Thank you in advance.. (New guy with 96 850 R)
Khyren
Year and Model: 1998
Has thanked: 3 times
Post by Khyren »
I had a Turbo Thunderbird years ago that would backfire at anything above 14psi. Turns out, it was a weak fuel pump that didn't have enough flow for the higher demands above that boost. I would check your fuel pressures, spark plugs, and maybe even ohm the coil if it is having the spark blow out.
Has thanked: 1609 times
Been thanked: 4065 times
Are all your ignition components stage 0?
These cars run open loop on boost so the tune has to be dialed in precisely to the turbo and induction by the tuner.
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
As mentioned above, what is the fitness of your ignition components?
Have you checked all of your hoses between the turbo and the intake?
Do you have a stock ECU to toss back in it?
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
If it cuts out with RPMs check ignition, if it cuts out with PSI check the CBV diaphragm especially if it wasn't refreshed recently. Swapping the ECU is a great troubleshooting idea.
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
+1 on all above.
These cars really prefer OE ignotion parts, especially the spark plugs and wires, distributor and rotor.
My 96 R did the same thing as yours on the stock tune when I bought it. After refreshing all ignition components it really came to life above 4000rpm.
1996 855 R,
2010 V70 D5,
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Chuck W wrote: 20 Feb 2022, 06:28 Do you have a stock ECU to toss back in it?
My first thought while read the lead post. Besides looking for the simple things like blown off vacuum lines and the condition of the spark plugs, I'd swap in a stock ECU. You don't even need to buy one if you know of or can find a friend with a HPT 850.
If it's not that, then what Abscate said... look at Stage 0 checklist.
Also -> Amazon link
