Do I need to fill VVT solenoid with oil? Topic is solved
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
I took the vvt unit off when I was replacing the head gasket. I am not putting it back together. Do I need to fill the holes that are on the cam cover and under where the vvt solenoid goes with oil, or not?
2002 v70 X/C 288k miles
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
Once you have the VVT solenoid torqued back on (w/new gasket that has screen) 1. turn the engine over manually (with oil in crankcase) to circulate oil, or 2. before firing, you can crank the engine (using the starter) with the ignition coils disconnected or fuse removed. That’ll get oil up there.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
EngineeringBloke
- Year and Model: 2006 2.5T S60
- Has thanked: 57 times
- Been thanked: 39 times
Surely oil drains out of the VVT, which is on top of the engine, whenever the engine is turned off. So first install of a dry solenoid would not be hugely different from any daily start up.
But if you can identify the fuse, it seems simple to do - once. I have both intake and exhaust VVT solenoids to do myself but no P0127 at the moment, so no rush for me.
- 5184 Views
Last post by LT South Africa
- 2082 Views
Last post by polskamafia mjl
- 2871 Views
Last post by Archer
- 3890 Views
Last post by Blacklab467
- 4216 Views
Last post by jimmy57
