Computer Fan For The Volvo Topic is solved
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Oka
Year and Model: XC70, 2001
Has thanked: 9 times
Been thanked: 4 times
Post by Oka »
Hello folks, I have an electrical question.
I need to use this fan from my old computer, in the Volvo, over the CEM module. All the fans I removed from the old PCs says 12VDC or DC 12V.
1. If the fan is ran by AC in the PC, why does it have a "12VDC" on the label?
2. Almost all the fans I have, has three wires (Red, Black and Yellow). For the car, I need to run one wire to the ground and the other to a fuse (Accessory/Ignition controlled). With the three wires, what should I do?
Thanks
2001 Volvo XC70/AWD/Auto/Turbo/146kMiles
2001 Volvo V70XC/AWD/Auto/Turbo/144kMiles
2002 Subaru Outback L.L. Bean/3.0/131K/AWD
2005 Volvo XC90/AWD/V8/Auto 111 Miles
2006 Toyota Sienna LE/AWD 93K
1985 BMW (E23) 735i(US)/AUTO/209K Miles (Parked since 2011)
1997 Mazda MPV/AUTO/4WD/173K Miles (Parked since 2008)
Oka
Post by Oka »
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
The third wire is probably certainly a variable speed input.
Also -> Amazon link
Has thanked: 1507 times
Been thanked: 3823 times
Because the first thing the AC hits in a PC is a power module making regulated 5 and 12 V DC
EngineeringBloke
Year and Model: 2006 2.5T S60
Has thanked: 55 times
Been thanked: 39 times
Post by EngineeringBloke »
As reported in a comment in the link to the other forum, the third wire is used to report RPM fan speed.
A PC power supply provides multiple different DC voltages. Case and other fans run on 12 volts DC. Modern PCs will reduce the supply voltage to allow the fans to run at lower speeds when reduced cooling is needed. Ends up being quieter and more energy efficient.
Just connect the red wire on your fan to 12 volts and the black to ground. Use a 12 volts connection that is switched off when the car is turned off, or you will drain the battery.
Some fans are 4 wire and these add a pulse width modulation input to the fan to directly control the speed.
02V70
Year and Model: 2002 V70XC
Has thanked: 53 times
Been thanked: 40 times
Post by 02V70 »
Cant, you just do Pulse Width modulation with the red/power wire?
2002 v70 X/C 288k miles
BlackBart
Has thanked: 927 times
Been thanked: 885 times
Post by BlackBart »
Fan...?
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
Why do you need to add a fan to your CEM?
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
There are a few reports of Volvos (early P2?) with over heating main computers under the dash. A solution is to add a fan or direct A/C flow at the CEM computer.
Search for more info.
matthew1
Site Admin
Post by matthew1 »
https://www.matthewsvolvosite.com/decre ... ilure-fan/
That points to discussion in the forum.
Also -> Amazon link
