1999 V70T5M climate blower fan motor failure , ECC Topic is solved
This topic is in the MVS Volvo Repair Database » V70 Climate Control (ECC) Blower Fix w Pix
Has thanked: 1505 times
Been thanked: 3818 times
Volvo Repair Database 1999 V70T5M climate blower fan motor failure , ECC
My blower motor went out tonight, it has been moaning on occasion for the past few months. No blower
Activity in any position of the slider switch .
Can I apply 12VDC to the motor to see if its the motor or resistor pack?
Thanks in advance
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Yes you can.
rmmagow
Year and Model: V70 1998
Post by rmmagow »
FWIW, I bought an aftermarket blower, TYC I think and it works very well. I think if the resistor was going out your blower would have been running at max all the time. First really easy job I did on my v70.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
A while back I tested my blower motors with a power supply and a current meter to see how much current was being drawn... I graphed it up here:
https://www.matthewsvolvosite.com/forums ... 2&p=278168
At about 8V, the fans (both new and old) were drawing between 10 and 11 Amps.
Update. While waiting for the kids in the driveway for school, I pulled the glovebox and put pressure on the white fan connector and the fan started running. It runs at low speed, sounding like a sick whale, but with more pressure runs at full speed.
It looks like there is some wiring in the housing between the actual fan motor (80 USD from a MVS supporting-vendor) as opposed to the whole blower/cage/fan assembly (180 USD from same)
I don't have time to troubleshoot so I ordered the whole cage and will report back some useful diagnostics so that others can diagnose motor vs motor/fan/cage problems.
Update - cleaned contacts over lunch, and fan started up. It is still speed dependent on pressure on the connector, so Im not happy with this as solution. New one on order comes tomorrow.
Swap took 10 minutes. EZ PZ.
I couldn't get the blower cage off the old motor so I'm glad I replaced the whole thing.
You can clean the Evap Core through the opening
With blower out you can access evap core
Blower motor is black plastic - held in with four screws
