We've been getting a lot of hits on our website from this forum, thanks! We also have this other set that has mm hex and stars (torx.) I originally designed it for bikes but lately many people have been buying them for cars http://chapmanmfg.com/products/1916-eur ... orycle-set
Here's a video of the set being used on a Toyota, our tools come in around 8:50
Thanks!
Do it yourself ABS module repair. Topic is solved
Do It Yourself ABS Module Repair
ChapmanMFG
- Year and Model: none :(
- Has thanked: 2655 times
- Been thanked: 1248 times
Save 10 on the chapman master setChapmanMFG wrote:Mathew 1, thanks so much for posting our tools on the homepage! Do you have a link?
It's still on MVS home page. I didn't get to it with much time before the offer expired. Can we do another?
ChapmanMFG
Sorry for the late response, sure! Use the code Volvo5575 for 10% off the Master Set http://chapmanmfg.com/products/master-kit-5575 or the code Volvo1916 for 10% off of the 1916 mm hex & star/torx set http://chapmanmfg.com/products/1916-eur ... orycle-set
The #1916 was originally designed for Euro/Japanese motorcycles, but many people are buying it for Euro cars because it has mm hex, slotted, phillips and star/torx bits in a super compact roll that you can stash in a glove box.
Both codes are unlimited/person (if you order multiple items you can use the code for each item) and expire August 1st. If you want to purchase both the 5575 and 1916, please place two orders and we will ship them together and refund you the shipping cost. Our system will not allow 2 different coupon codes being used on the same order. Any questions please e-mail or call!
Thanks!!!
Joel Camassar
[email protected]
860-349-9228 (Say "Hi" to Peggy and Rebecca!)
Thanks!!!
Joel Camassar
[email protected]
My first repair lasted 6 years. Instead of doing it again, I sent it to mattymoo (www.midwest-abs.com). Excellent decision!
HiGertSkronewald wrote:Hi guys.
I read through all the posts up until the last page and realised my brother is not the only one who's box can probably not be repaired...
Attached are 2 photo's of how his 2003 model S60 T5's ABS box looks inside... as you can see there is no soldering... how to fix this one?!
I cant believe that it is IMPOSSIBLE to fix...i mean, as my brother said, componenets rarely fail, its mostly the power supply of the components that fail, or develop dry joints because of heat/stress.
I also drive an 2001 S60, also started with the same ABS errors.
Any suggestions?
Did you solve the problem wih your abs module ?
- Pushi
- Year and Model: 1997 v70 2.5T
- Has thanked: 2 times
Hi.
I am a newly registered member, but already reading this website since april ,when I bought my p80 v70 2.5T from 1997.
Already finished the pcv projects few weeks ago, followed by Justin Blackburn instructions .
Now the abs module problem fixed and I would like to say a huge thank you for every member,who's sharing the informations all across this on this page!
Thanks
Pushi
Manchester, UK
Thanks
Pushi
Manchester, UK
- Has thanked: 1505 times
- Been thanked: 3818 times
Great pictures of the solder cracks.
Thats a great colour, too!!
- Pushi
Thanks!
I love this car!
I soldered 4 pcs this side and the 2 main connectors other side. Not sealed properly of the case (only used gorilla tape all around) at the moment, because just waiting the next few days whats going on..coming back the fault or not .
I love this car!
Hello, guys please give advice or solution. My problem is the error "brake failure stop safely - 98" and spaces instead of letters & numbers. Also, automatic transmission in position "D" and "4" sometimes do not engage gear, just increase speed engine, then finally engage the gear and skip it because of the load too much.
In position "3" all engages are fine.
Sorry for my english.
Privetstvuyu
This is probably not an ABS failure causing the transmission to skip. Can you get the car to someone who can read the codes ? It could be a simple thing like a wheel sensor
s uvazheniyem, abscate
