850 Petrol part on fuel line
manovlov
Has thanked: 620 times
Been thanked: 143 times
Post by manovlov »
Hy Guys,
As i was working on reinstall new fuel hoses lines, i've seen this part. Do i need to change it, because mine is rather rusty on the outside. What is the function of this part ? A fuel pressure ?
Manov
850 Fuel line part.png (131.39 KiB) Viewed 155 times
jreed
Has thanked: 352 times
Been thanked: 192 times
Post by jreed »
I'm not sure what it is, but could it be a damper?
Has thanked: 1853 times
Been thanked: 1714 times
Can you post the whole drawing as I don't recognize the part from what I can see. It could be a pressure regulator or one way valve.
manovlov
Post by manovlov »
scot850 wrote: 17 Oct 2025, 08:37 Can you post the whole drawing as I don't recognize the part from what I can see. It could be a pressure regulator or one way valve.
Here you are. N° 13.
850 Fuel lines.png (212.37 KiB) Viewed 138 times
Although not listed, I think it is called a fuel pulse regulator. I can only think it is a device to steady fuel flow pressure. I have attached the fuel line it is part of, however, in this case for North America, it lists it is only fitted with the fuel pulse regulator on certain chassis number ranges:
https://www.volvocarstorontoparts.ca/p/ ... 42683.html
Perhaps your car does not have one fitted?
manovlov
Post by manovlov »
scot850 wrote: 17 Oct 2025, 14:04 Although not listed, I think it is called a fuel pulse regulator. I can only think it is a device to steady fuel flow pressure. I have attached the fuel line it is part of, however, in this case for North America, it lists it is only fitted with the fuel pulse regulator on certain chassis number ranges:
I don't know. This part is on the line, i will let it in place. But i will have to unplug it because the replacement of fuel line. It will be the opportunity to have a closer look and to clean it. Pictures to come.
Thanks Neil.
Year and Model: 2001 V70
Has thanked: 928 times
Been thanked: 1002 times
Post by volvolugnut »
My 1975 245 had a similar looking part that rusted out soon after I purchased the car about 1990. The replacement came from Volvo dealer and was called pressure damper.
manovlov
Post by manovlov »
I will take it apart carefully and clean it, before to plug it to new fuel line...
Thanks volvolugnut
jreed
Post by jreed »
There is some more info on the fuel pulse damper here:
viewtopic.php?t=106472
viewtopic.php?t=43206
Interesting that is shown as part of the fuel rail, and the parts drawing shows it as part of the pipework. Hm.
