Bought a budget boroscope to check the cylinders out.
The car burns oil, especially at stop lights and long idle.
Compression is evenly across all cylinders. I don’t have a compressor to perform a leak test.
Any guesses on the pictures if a valve stem seal job is enough?
The car has 450k km currently. I drive less that 7500km a year.
How are my cylinders looking?
- Sveedy
- Has thanked: 417 times
- Been thanked: 457 times
Those cylinders look beautiful. New seals and you should be good to go.
1999 V70 GLT
1999 V70 GLT
- Has thanked: 927 times
- Been thanked: 1000 times
Yes, good cross hatch honing pattern.
- Has thanked: 1850 times
- Been thanked: 1712 times
Agree as well. As already mentioned, new valve stem seals are needed.
Chieber
- Year and Model: 1998 v70
- Has thanked: 45 times
- Been thanked: 30 times
Thanks all!
I’ll put the valve stem seals Ann’s tools on my to buy list for the next round of repairs. Unless it doesn’t pass emission tests that’s soon to be due.
1/2 a shitbox V70 1998 2.5 NA
- Has thanked: 1505 times
- Been thanked: 3818 times
Buy the stem seals in the kit, not by the piece. Since you live in the Health Care side of the Atlantic , you can get them from Skandix.de pretty cheaply
The kit has both the seals and the little protective nipples if you choose the sadistic path of doing the stem seals with the head on
giovannibianco
- Year and Model: 850 1994 v70 1998
- Been thanked: 2 times
Hello,
Hey can you point me towards the model of boroscope that you bought? I'm intrigued as it seems you can "look back up to the spark plug hole that the wire has come through... Did you get it from Aliexpress?
Cheers, John.
Cheers, John.
Chieber
I bought the cheapest one since I don’t use it daily. My only requirement was that it does have a articulating camera to swivel up and down.giovannibianco wrote: ↑28 Dec 2025, 11:08 Hello,
Cheers, John.
The resolution and lighting is so-so if you compare it to what yt’ers use. But those boroscopes are like ten times more expensive.
https://a.aliexpress.com/_Ew1JzLm
- wizechatmgr
- Been thanked: 126 times
According to AliExpress - not able to be shipped to USA for those wondering... Almost like they are tired of the tariff gotchas.
- ZionXIX
- Has thanked: 65 times
- Been thanked: 194 times
- 793 Views
Last post by stephansvolvo
- 13 Replies
- 4751 Views
Last post by draser
