I have a USA 1996 854 n/a manual transmission
I just picked up a trip computer and installed it, only to find out the bulbs were bad. No problem, I picked up a couple of osram 12/1.2 bulbs at the local Volvo dealer for $3 and installed them. Now I'm noticing that the INFO switch that controls the trip computer doesn't light up. Is it supposed to? Can that bulb be changed or should I look for another switch?
Also, one of my seat heater switch lights is out. If the slider for the dash light intensity is supposed to light up, that one is out too (though the rear-fog-lamp switch which looks to be part of the same unit is working fine).
Any suggestions would be much appreciated. Thanks.
Bulbs, bulbs, bulbs...interior bulbs.
Interior bulbs designation, sizes, etc.
The INFO switch light is the same bulb as all of the other switches. You can buy a totally new switch and simply pop the existing switch out. Remove the lower panel and then push the switch out from the back. Then press the new switch back in from the front. This is probably the easiest, but most expensive.findude wrote:I have a USA 1996 854 n/a manual transmission
If you look at page 1 & 2 of this thread it has the part numbers for the light bulb itself. The bulb is removable and replaceable. It's the same bulb for the rear fog lamp switch and the other switches nearby.
Can anyone help with this problem I'm having with interior lights on my '96 850 Turbo? My passenger side interior light (the one located inside the module where the sunroof motor is located) 'went out'. When I popped the light cover off, the bulb fell out. Thinking it wasn't really 'out', I pushed the bulb back in its holder, turned 1/4 turn, and now NONE of the interior lights (front or back) work and I have a constant chime. To get rid of the chime, I had to turn the interior light switch to the 0 position.
Any suggestions???? I would replace the entire module with one from a junkyard but the fact the rear lights are out too confuses me.
- Year and Model: Many Volvos
- Been thanked: 75 times
Check fuses 3, 6, 10 and 15, replace as necessary and it should get rid of the chime.
double_platinum
- Year and Model:
Ok another bulb that should be included in the list is the transmission indicator bulb. Didn't see any posts in this thread or others on it, and it would probably fit in here. Also works out that I need to do mine and would like some pointers on how to access it. Anyone got a good link to instructions so I don't crack the wood on the center console trying to figure it out?
96 855 Turbo Platinum edition 137K
96 854 Turbo Platinum edition 211K
94 965 271K
94 965 271K
Solutech did a good writeup in this thread:
https://www.matthewsvolvosite.com/forums ... hp?p=52763
It is a right hand drive car but the basics are the same.
The lamp itself is unique and expensive. I use a Dremmel tool to cut the leads off of the old lamp and solder in a Radio Shack 272-1092 back into the socket. The same style lamp illuminates the cigarette lighter ring.
double_platinum
- Year and Model:
Thanks Lee, and now for my final question since I will be in there replacing the rest of the bunk lights, I have been looking for this one too, is there a thread on replacing the E-W-S transmission mode control switch lighting as well? If we can get this then I think we would have all the bulbs in the dash and center console all on this one thread (as long as the SS link doesn't move)
94 965 271K
94 965 271K
I looked it up in VADIS and they don't show a lamp in that switch. I can't recall whether mine is illuminated or not. Some of the switches - the Info switch for example - have the lamp soldered in place inside of the switch and it is necessary to take the switch apart to replace it. All of the older, Pre-95, switches were made that way. I have taken a few of them apart to replace the lamps but it is not a procedure I would recommend for everyone. The entire switch falls apart and springs go flying. They are a challenge to get back together.
double_platinum
- Year and Model:
I have a spare switch with a slightly broken cover I might go ahead and pull apart tonight. Will post pics and info if I find anything. Would make sense that it would light up, though I have to admit, I have never seen one that was functioning
94 965 271K
94 965 271K
