EGR Leak
TurboWagon
- Year and Model: 1994 Volvo 850 Wagon
I've been getting code 1-5-4 which means EGR leak, is this just a vacuum leak, or does the entire unit need to be replaced, I've taken the manifold off to get at the knock sensors, so I figure now's as good a time as any.
It means that the EGR valve is letting some exhaust gas to go into the intake when it shouldn´t. The EGR valve acts on a open or closed cycle, and is commanded by the ECU. It should be open only under certain conditions. If it is leaking, even at idle, it means it is not shutting off completely as it should. One of the symptom is that at idle you will have some small oscilations in RPM, if you listen carefully.
You might try to clean the EGR up, by letting it soak in carburator cleaner overnight, and removing all the crud that gets accumulated inside it. After it is totally cleaned up, you can check if its is ok by trying to blow thru the large opening that connects to the exhaust pipe that goes to the back of the engine. If it is ok, it will not let any air go thru. However if you can blow some air thru it, even in small volumes, you will have to replace the valve, as it is not serviceable. With some luck, it may be just accumulated crud that is not letting proper closure.
Do not forget to clear the hole where it attaches to the intake manifold.
1995 859 auto NA
TurboWagon
Thanks for the help, I'll let it soak hopefully won't need a new valve, those things are expensive!
- 691 Views
Last post by Ozark Lee
- 801 Views
Last post by erikv11
- 747 Views
Last post by southofmotown
- 13 Replies
- 7105 Views
- 3491 Views
Last post by tryingbe
