torn cv boot. Replacement recommendations?
Torn CV boot. Axles or CV Boot Kit?
- hanzbe420
- Year and Model: 2006 s60 2.5T
Hi all. I was looking under my car when i saw the torn CV boot and Grease all over my passenger rim. Now is there 2 axles 1 for each side or just 1 whole part i can buy?? and any other parts that i will need like seals or anything? and what site should i order from that has the best quality and price deal. please let me no. 1994 Volvo 850 turbo wagon. Links to exact parts would be appreciated!
- Has thanked: 311 times
- Been thanked: 817 times
There are two axles, one for each side. You can either replace the boot, or the entire passenger (right) side axle.
To replace the boot there is fantastic advice on this site from a cn90 tutorial. He'll probably post if he hasn't already while I am writing this
I personally would replace the axle, but it is your call. Axles you can buy cheap (~$85 at fcp) new replacements that work some of the time, the new EMPI axle which is supposedly better (~$116 at fcp) or you can spend about $180 and get a perfect rebuilt Volvo axle with forever guarantee from raxles.com. I went the latter route on both axles for my car, the guy there is named Marty you can call him.
The other part you need is one axle seal, get OEM http://www.fcpgroton.com/product-exec/p ... ory_id/103
- Been thanked: 504 times
Read my Update from October 09, 2011!
Stick to GKN boot (about $11/each, axle nut is cluded in the kit):
https://www.matthewsvolvosite.com/forums ... hp?t=29716
- hanzbe420
I am about to just get the right front axle Cause I am pretty sure a bunch of crud got in there,and there stock 125k so ill just get a new one. Hows the 1 from fcperuo will i need any addition parts for this one right here? http://www.fcpeuro.com/products/volvo-c ... ront-right ... or is this one crappy? there's also a duralast one from auto zone for like 60, or what? please let me no! And to witch extra parts i will need as in a axle seal or what?
If CV joint still good (no clicking during turn). Keep the axle.
Just renew the boot.
If the CV Joint is gone, then your best bet is raxles dot com (warranted for life).
Duralast is hit-and-miss, it may be a rebuilt Volvo one, it may be some Chinese knock-off.
- Has thanked: 2860 times
- Been thanked: 1332 times
Just did my driver's side axle. Went to CarQuest and got a reman for $75 (with core swap). See this WorldPac axle post.
No problems. Runs smooth as silk.
- hanzbe420
yea Matt? http://www.autozone.com/autozone/parts/ ... _1159_4231 how about this duralast .reman from auto zone. reman is duralast? or should i get the one from fcp or raxle? I am not gonna just do the boot. Because i have to still drive this around and by the time i fix it, it will probably be ticking.
I wouldn't get that new fcp axle you listed. If you are not wanting to spend up for raxles.com, get the EMPI from fcp.
You need two parts, an axle and a seal. Some people don't replace the seal if it isn't leaking, but I would replace it. Just be careful putting it in, be sure to read up on how to do this job. It is a pretty easy one.
axle http://www.fcpeuro.com/products/volvo-c ... ront-right
seal http://www.fcpeuro.com/products/volvo-a ... al-6843112
The WorldPac may be fine, I do not have an informed opinion on that one.
I agree with Eric, I bought an EMPI about 82K ago and no problems. I put an auto zone axle in the left side and got 22K and it started burbling. Auto Zone offered to warranty it, but i insisted on store credit (oil and such) just bought another EMPI.
By the way, I used Euro15 in the discount code and got 15% off with free shipping! That was about 6 weeks ago, so i'm not sure it still works....but worth a try!
- 11 Replies
- 5949 Views
Last post by default
- 2227 Views
Last post by ferocity02
- 788 Views
Last post by yanga001
- 920 Views
Last post by CThompson
- 1654 Views
Last post by erikv11
