XEMODEX and SACER TPS - same design?
EstVolvo
Year and Model: 2000 V70
Post by EstVolvo »
Is there a difference between the Sacer and the Xemodex TPS design?
I have see many pictures of the ETM with Sacer TPS but no pictures of the XeModex TPS design.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
I've seen the Sacer, XeModex and Volvo contactless TPS and the castings and design are identical. Apart from a logo casting change they are the same.
My contact at Sacer tells me that they directly supply to XeModex and Volvo.
When you purchase a rebuilt 36050563 or 36050564 throttle from Volvo it will also have a Sacer TPS with a Volvo logo these days.
Bear in mind that XeModex rebuild the circuit board with new wedge bonding joints, rebuild the magnet and adjust the resting voltage.
RickHaleParker
Been thanked: 979 times
Post by RickHaleParker »
Careful, Sacer does have a conversion TPS (SA300) that can be a real PITA.
viewtopic.php?f=9&t=84162
viewtopic.php?t=65275
viewtopic.php?p=341961
viewtopic.php?f=12&t=58045
viewtopic.php?t=38504
Active
Past
precopster
Wow that's a lot of Anecdata!! :D
Most ETMs are converted to contact-less without thoughtful analysis of the fault codes; at least 60-70% of ETMs have board faults and magnet problems.
