2007 S 80 FWD 3.2 -- Upper Torque Rod Replacement Topic is solved
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
I've replaced numerous P80 and even P2 torque rods. Have to do it on a 2007 S80. Looks like I'll have to move the coolant overflow tank to get the long mounting bolt out. Anybody ever done it and is moving the coolant tank the trick? If so, anything I have to watch out for in moving the coolant overflow tank? Thanks.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Moving the coolant overflow tank to get to the Upper Torque Rod is by the book. Bolt torque is 110 Nm (81 ft-lb).
IronMike
Year and Model: 2007 S80 3.2
Has thanked: 5 times
Been thanked: 4 times
Post by IronMike »
81 ft/lbs seemed like a lot for these. Can someone please confirm this is the torque for BOTH bolts for the upper torque rod?
RickHaleParker
IronMike wrote: 29 Feb 2020, 15:29 81 ft/lbs seemed like a lot for these. Can someone please confirm this is the torque for BOTH bolts for the upper torque rod?
E Showell
Post by E Showell »
Update:. For me this turned out not to be a one person job. When the bolts were removed, the engine rotated, so that I could then not align the mounting holes. I ended up having to take it to my mechanic. Two people needed to do this job.
'95 855 auto (sold)
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
If the engine moved when you removed the torque rod then the motor mount is likely broken and it needs to be replaced
https://www.freel2.com/forum/topic32979.html
Take care
Paul
E Showell
Post by E Showell »
Correction -- Replacing the torque rod wasn't an issue, but during the course of that replacement, I realized that the hydraulic engine mount underneath was shot. When I removed the bolts for the metal cover over that mount, and after replacing the mount, I could not get the upper metal cover bolt holes to line up with those in the hydraulic mount since the engine appeared to have shifted slightly. Thus, it was not a one person job for me and ended up going to my local mechanic to complete.
'95 855 auto (sold)
IronMike
Post by IronMike »
RickHaleParker wrote: 29 Feb 2020, 16:43
THANK YOU!
