Wow, I'd better drop down a bit on my 500lb estimate of engine/tranny. Unless you guys are some steroid-pumped body builders!9394volvo850s wrote:me and a friend can lift a volvo 5 cyl in and out of the trunk of my 850. for install and removal your gonna want a hoist. leave the tranny bolted up.
C@lvin,
I pulled one engine separate from the tranny, and found it more difficult due to the space needed to disengage the engine from the tranny. That lateral 5-pot engine doesn't leave much extra space to move things around. If you pull as an assembly, the transmission can easily be removed while the engine is up in the air, or even with it sitting on the shop floor on a couple wood blocks.
