1997 850 T5 Alarm issue
goober4321
- Year and Model:
Something strange started recently. My perimter lights will flash once every 3 minutes and the factory alarm resets itslef and you can hear the locks re-locking themselves. I have tried open and closing all doors, trunk, hood etc to no avail.........I am not sure where I should look next. Any help??
- Year and Model: Many Volvos
- Been thanked: 76 times
It sounds like you either have a failing alarm relay or a faulty door switch. Do the doors try to lock and unlock themselves while you are driving?
You can bypass the entire alarm system by removing Relay 210 / 211, it is located high on the firewall, inside the car, directly below where the fuse box is. After you remove the relay the car will not start until you add a jumper wire between the socket positions associated with pins 50E and 50F on the 210 side of the relay. If you decide to permanently disable the alarm Volvo sells a dummy 210 relay that has the jumper wire built into it.
goober4321
- Year and Model:
Thanks Lee.......and no th elocks do not try to lock themselves while driving. So could it be the alarm relay.....the same one you mentioned 210/211?
That is the one, be prepared for some major contortionism while trying to deal with it.
goober4321
- Year and Model:
No probs.......thanks for the tip.......is that relay a special one or can it be substituted for another temporarily till I can get a new one?
That relay is specific to the slot, there really is not other relay that will fit into the socket.
They are more than just a standard relay, they have solid state devices in them with timing components to make it all work.
goober4321
- Year and Model:
ok thanks again. hopefully that cures the problem
cheapwagon
- Year and Model:
Is this the same for the 98 s70? Any chance you have a p/n for the dummy relay?
97 855 GLT somewhere around 214k
I don't think so, If I am not mistaken they went to the chipped keys and changed the entire immobilizer system on the V / S series. If you do have relay 210 / 211 the dummy relay for 210 shows in VADIS as pn 3345333.Is this the same for the 98 s70? Any chance you have a p/n for the dummy relay?
- 4180 Views
Last post by ZootAllures
- 1913 Views
Last post by jonesg
- 2351 Views
Last post by Sailsman
- 1054 Views
Last post by thr3shold
- 1234 Views
Last post by vtl
