240, 1993, locate headlight relay
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
kaerlighedsbamsen
Year and Model:
Post by kaerlighedsbamsen »
The high beam/low beam shifter works only once in a while. It will shift to high beam but returns to low as soon as the arm is released. I suspect the headlight relay to be malfunctioning.
- How do i locate the relay? It does not seem to sit around the others under the instruments and beside the fuses as the rest of the relays.
- Does anyone know how to test and if in need to repair a relay?
- Are there any other places to look for faults?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
It is next to the battery.
240 headlight relay.pdf
(48.43 KiB) Downloaded 651 times
The only way to test a relay is by replacing it with a known good one.
You can open the case to see if any solder joints have come apart and re-solder them.
The switch itself may have developed a fault.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
kaerlighedsbamsen
Year and Model:
Bill you are once again a star! Will return with resuts.
Best of luck!
Ty
