Hi,
I get a humming noise when turning my wheel at low speeds...really only hear it when its cold out.
I also have a clunking sound when stepping on the brakes and coming to a stop when in reverse in any temp.
CV Joint problem??
Appreciate any insight.
Thanks
George
2001 S60 2.4T: Noise when Turning Wheel at low speeds
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
Could be a number of things- first of all, check your automatic steering fluid to see if it's low- only top off with what's recommended in your owner's manual- not power steering fluid sold at the autozone. The clunking, unfortunately is something that '01 transmissions were prone to- could be a stop-neutral issue that can be solved by the latest transmission software upgrade or it could be something more- just make sure you have the latest software fix. Good luck
- 11 Replies
- 607 Views
- 9 Replies
- 4648 Views
Last post by theWIFES_S70
