#12 fuse blows constantly Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Tjchillingham
Post by Tjchillingham »
I have a 90 240 DL that is blowing the #12 fuse. I have tried replacing the power window relay, but I'm not sure if I changed the right one. I found two under the center console a/c vents and tried the new relay in place of them both, but the fuse still blows. The passenger taillight doesn't work quite right, could that be related? The only wiring diagram I have is the crappy Haynes one. Please help.
LaRy
Year and Model:
Post by LaRy »
In the crappy Haynes wiring diagram you can see that the fuse is also feeding switch #23, reverse light switch at gearbox. It could be some short circuit under there. A good way of trouble shooting a blowing fuse is to remove those wires connected to fuse #12 output. Check the resistance between each separated wire to ground. A value less than ~1 Ohm will blow the fuse. The you will have some wire to follow.
