GL!
Im learning to live with the abs light... lol of course once I get my interior done its on to the small things, and that is on the top ten.
Do it yourself ABS module repair. Topic is solved
Do It Yourself ABS Module Repair
- RobTheModd
- Year and Model: 98 S70T5M
- Has thanked: 5 times
- Been thanked: 7 times
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
I'd wager good money to say it's a lifetime fix, only because I've done a ton of soldering over time. Any cold soldered connection isn't going to hold up with vibration and temp changes. Resoldering the pins changes the bond entirely. If those pins were preheated at the factory they would have never cracked.marginal wrote:I agree with you fattymatty.
But, let's see how reliable is our repair.
Let's not forget, all of our ABS modules have worked for a certain period of time, after what, the solder joint has cracked.
Time will tell.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Matty Moo
Here's the killer tip.
Using a bench vise and a wonderbar (stanley prybar). You can have one of these cracked open in under 3 minutes or less without doing any cutting or damage to the case. Just run a utility knife around in the deep groove of the case, set it in the vise and use the bar to break the seal.
I'll take a pic next time I do one and post it
2000 s70 GLT
2014 Ram
guys I finished my job, it is fantastic. I ll try to share my experience
Yesterday i was tryin to find the external torx socket and couldnt get from any where. but suddenly today i got the idea of using a normal socket. I used 5mm 6point socket, 4mm also can be used as the bolt head is smaller to the end. After taking the module I spent nearly half n hour to open it, finally i broke the lockes and managed to open, I couldn't find any crack from any or the pin. so i resoldered all the pins including the small pin came from the big connecter. and cleaned bote side of the connecters and put it back.
I was very frustrated to see the ABS light and the track off light on. danm it!!
but just got in the car and enjoyed lil bit in the black ice ijn my back yard
wow light gone, so then i took it to the streeet and highway, it worked, it didnt come back wooohoo
My next job is the danm check engine light. will find the code and cyaa guys
thanks guys for providing informations, I have photos will update later
nw gtg
thanks guys
nw gtg
thanks guys
ok it seems from what I am reading here concerning the "ABS" & "TRAC" lights intermittently turning on and the "speedo" dropping out as well as the check engine light turning on ,things seem to point to the "ABS" unit. I been pounding my brain trying to figure this problem out.it sounds like I need to pull my ABS unit and try the suggested repair. thank you all for the suggestions .and wish me luck.
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
I have never seen or heard about the engine light being related to the ABS module, but certainly your module is bad. The instructions posted here will fix your speedo and ABS issues no problem.
- Jesse
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
well I have to say thank you to all of you who have given input on the subject of re-soldering the "ABS" unit.I went to work on it at about 11:30 pm last night and finished about 1:20 am .re-installed the unit reset my check engine light and took it fro a lil drive .yupper's good fix .good input from every one as well.now to figure out how to reset the "SRS" light I could use some suggestions.
Vince
1999 basic S70 teal blue
Vince
cpdinc1800
- Year and Model: 850 1996
I just purchased a 1996 850GLT. The ABS light occasionally comes on while driving. The ABS works- I tried it a few times. But my other issues are the speedometer reads about 10mph lower than actual speed measured with a GPS (tires are 195/60/15-stock size), the tach reads zero at idle and about 2000 at 70mph (again measured off the GPS), plus the fuel guage reads lower than it should (the previous owner replaced the fuel pump, so that may just be him replacing the sending unit incorrectly). Does all or most of this sound like the ABS module? Thanks in advance for any help provided.
CPD inc 1800
CPD inc 1800
- Year and Model: Many Volvos
- Been thanked: 76 times
Welcome to MVS.
Your problems could be a failing module but, since it is intermittent, it is more likely dirty reluctance rings for the wheel sensors. The fronts are fairly easy to get to from the back side of the hubs but for the rears you will need to remove the calipers and the rotors.
This thread will be helpful for the rears:
https://www.matthewsvolvosite.com/forums ... 6225#26225
The problems with the instrument cluster are more than likely as a result of the cluster not being properly reset to zero after an odometer gear replacement. Snap a picture of your instrument cluster with the key off and post it back.
cpdinc1800
I suspect you are correct about not setting the dash back to zero, based on where the needles sit when the car is off. The dash has definitely been removed. I will find the posts about replacing the speedo gear and see if I can reset it. Thanks. And as for the ABS, I'll have to wait for some warm weather to tackle that project. Thanks again for your help.
- december 2009 1 006.JPG (196.27 KiB) Viewed 3350 times
- december 2009 1 007.JPG (199.67 KiB) Viewed 3350 times
- december 2009 1 008.JPG (200.82 KiB) Viewed 3350 times
