V70 XC 98 Possible MAF?
Glencoeteen
- Year and Model: 00 V70R
Hey guys. So i have the Famous CEL, The car runs pretty good. more or less Stage 0 just took it to Vancouver B.C and back from Portland, Oregon with no problems. i have my own OBD-II reader which i use on every type of car i own and it gave me a P0112 Code...Intake Temperature Sensor Low Circuit. Some have told me its part of the MAF.. When the car is running I can unplug the MAF it will run a little rough for about 4 seconds then idle no problem. but once i go to plug it back in.. engine still running it dies right away... so does this mean the MAF is bad? most cars i have worked on died or ran extremely poor when the MAF was unplugged. so any and all help will be great! IPD wants 180 for a new MAP or the wrecking yard down the road from them will sell me one for 50 bucks.....
98 V70XC~ Sold
98 S70 T5 ~ Stolen ;(
08 Xc90 V8 ~ Totaled
98 Expedition EB weekend warrior
98 S70 T5~ New project!
on most newer cars, yes the iat is integral to the maf sensor. but on a 98 probably not. i had the same code in my 98 s70 turbo. took about an hour to figure out it was refering to the temp sensor mounted in the lower facia. i had removed the front lower splash shield (sensor mounts in splash shield) for service and left it off to verify leak was repaired. yours coulda been racked on a curb or road debris or just a fault in the sensor itself. if im not mistaken the iat temp the pcm sees is inferred on these vehicles between a couple of diff sensors. you could check it with an ohm meter if you know the resistance values for a given temperature
Glencoeteen
Yeah someone told me that was what was normally wrong.. So i went to a wrecking yard im friends with the owner.. and he gave me two of those sensors and iv tryed them both and still have that CEL so im not sure whats going on.. both of the cars i took them from were wrecked and in running condition...
volvslow wrote:on most newer cars, yes the iat is integral to the maf sensor. but on a 98 probably not. i had the same code in my 98 s70 turbo. took about an hour to figure out it was refering to the temp sensor mounted in the lower facia. i had removed the front lower splash shield (sensor mounts in splash shield) for service and left it off to verify leak was repaired. yours coulda been racked on a curb or road debris or just a fault in the sensor itself. if im not mistaken the iat temp the pcm sees is inferred on these vehicles between a couple of diff sensors. you could check it with an ohm meter if you know the resistance values for a given temperature
98 V70XC~ Sold
$153 for Bosch MAF shipped.
use MVSCC discount code
http://www.fcpgroton.com/product-exec/p ... 1998_Bosch_
Black 1998 V70XC 183k+
ouch! i wouldnt load the parts shotgun until you verify the cause of the concern. do some research and see what other sensors the the pcm uses to infer the intake air temperature. have you verified the circuit of the above mentioned sensor back to the pcm? youll probably need a wiring diagram with the pcm pinouts. and also the normal circuit voltage or resistance, i would assume it would be 5 volts? do you have a scanner that can read pid data? you would then beable to see what temp it is reading
Glencoeteen
I have a Actron CP9185 Elite AutoScanne best one Autozone had. and i also had one from IPD the Scantron II and it read the same Code.... P0112........ I love my Volvo and never had any trouble and always easy fixes but this Code is that hardest and most difficult one iv ran into. come the 18th my Temp permit is Expired. and i cant pass DEQ due to the CEL
volvslow wrote:ouch! i wouldnt load the parts shotgun until you verify the cause of the concern. do some research and see what other sensors the the pcm uses to infer the intake air temperature. have you verified the circuit of the above mentioned sensor back to the pcm? youll probably need a wiring diagram with the pcm pinouts. and also the normal circuit voltage or resistance, i would assume it would be 5 volts? do you have a scanner that can read pid data? you would then beable to see what temp it is reading
98 V70XC~ Sold
Glencoeteen
From what it shows a constant -40... Ambient is 45 right now. so that means the temp sensor in the MAF is not reading correctly?
98 V70XC~ Sold
wheelsup
- Year and Model:
- Has thanked: 15 times
- Been thanked: 20 times
Have you cleaned the MAF yet? That fixed mine for a few months. Also I assume you cleared the codes before and then after plugging the new MAF in, correct?
1995 850 GLT Wagon w/ 200,000 miles
Glencoeteen
i have not replaced the MAF yet that is the last thing i want to do
98 V70XC~ Sold
