I need the spark plug firing order for 99 S80.
I was coded misfire on 4th cylinder.
How do I find out which is the 4th cylinder?
99 S80 spark plug firing order
537playing
- Year and Model: 2005 S60
- Been thanked: 5 times
Simple. Straight six engine is numbered one thru six starting at the timing belt or the passenger side of engine.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Look for any obvious cracking in the plastic on the ignition coil for that cylinder. And the condition of the spark plug itself of course
'98 S70 T5
2016 Chevy Cruze Premier
ovlov76
- Year and Model: S80 2000
For what it's worth, the answer to the question of what is the firing order, the answer is 1-5-3-6-2-4. As far as I am aware that is it for all straight 6 engines (not necessarily V6's). And yes number one is located at the timing belt, or the front, or even the RH side of the engine bay. Not all passengers are placed on the RH side......
Is this also applicable with my old 2007 Volvo S80 Spark Plug? Sorry for this silly question but im just a newbie when it comes to some technical terms and technical stuffs.537playing wrote:Simple. Straight six engine is numbered one thru six starting at the timing belt or the passenger side of engine.
- 3711 Views
Last post by MadeInJapan
- 6280 Views
- 3134 Views
Last post by Roger_850T
- 3949 Views
- 1973 Views
