I went camping last weekend and only drove my car 100 yards to the boat slip twice. When we packed up to leave, the reverse gear did not engage. The engine idled down as if to change gears but I had no reverse. ALl other gears worked. Strange! Well, I was able to drive car out and home and when I got home the reversed worked.
Any Ideas?
Reverse Gear 850 wagon
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I think it could be a PNP switch issue. But I would pull out the yellow transmission stick (near the battery, kinda hidden under pipes on mine) and look at the color of the transmission fluid. If it's anything but a bright, clear red it needs to be flushed/changed.
Try to find a big hill and try to back up it. Hopefully the transmission isn't slipping.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
Codes are good! (for us to help anyway, not so much for you having them). What codes did you pull?
The PNP (park-neutral-position) switch is under the console of the car, and helps tell the TCU what position the gear shifter is in. Sometimes it can be made to stop acting up by ratcheting the shifter quickly back and forth between P and L (engine off) 20 times or so. If that works, the switch will need to eventually need to be replaced.
'98 S70 T5
- 2476 Views
Last post by MDK
- 1503 Views
Last post by matthew1
- 11 Replies
- 2516 Views
Last post by 4sdAIR
- 1525 Views
Last post by s80volvo2004
- 674 Views
Last post by MadeInJapan
