5 sp auto tranny drain and fill question....
C@lvin
- Year and Model:
- Been thanked: 2 times
How much fluid comes out/goes back in for the 5 speed auto on my 2000 V70? I know for my 98 S70 with the 4 speed it is about 3.25 quarts, is it any different for the 5 speed?
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Suit yourself but myself and many others recommend the drain and fill method.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
If the fluid has not been changed in a long time, I think initially 3 drain and fills is much better than shocking the system with all new fluid. After the new fluid from the initial drain+fills has had time to clean up gunk and junk through normal use, then I think the cooler line flush is ideal.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
jblackburn
Agreed.If the fluid has not been changed in a long time, I think initially 3 drain and fills is much better than shocking the system with all new fluid. After the new fluid from the initial drain+fills has had time to clean up gunk and junk through normal use, then I think the cooler line flush is ideal.
'98 S70 T5
- 2867 Views
Last post by Archer
- 10 Replies
- 3873 Views
Last post by Blacklab467
- 2068 Views
Last post by polskamafia mjl
- 9 Replies
- 1959 Views
Last post by johngxc
- 19 Replies
- 4789 Views
Last post by dikidera
