740 Power Window Problems
SniperC4007
- Year and Model:
Try to manually raise the window...
Sniper>>
________________
1986 Toyota Corolla SR5
1986 Volvo 740 GLE
1989 BMW 535i
________________
1986 Volvo 740 GLE
1989 BMW 535i
Kmaniac in California USA
- Year and Model:
I suspect you have a loose electrical connection at the main power window switch in the driver's door. Even one dropped or broken wire can disable the entire system. Take your driver door panel off and check the connections at the switch. If you haven't done this before, follow this procedure:
There are three retaining clips on the underside edge of the door panel. Lie on the ground and look up at the bottom of your door, and you will see them. Pull the retaining clips.
There is another retaining clip hiding behind the red safety light on the rear edge of the panel. Remove the red lense to expose the clip and remove the clip.
Pop off the speaker cover, it is pressed on. Then remove any retaining screws.
Unscrew and remove the lock botton.
Inside the door handle well, you will see what looks like a plastic flathead screw. Stick a straight blade screwdriver into the slot and turn a quarter turn.
On the top of the inside door handle knob, you will see a rubber plug. Remove the plug to expose the mounting screw. Unscrew the knob and remove.
Now the panel will be ready to take off. Lift up and out to remove. Then disconnect and electrical connections.
Let us know what you find.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
1986 740 GLE
- 388 Views
Last post by wegelius
- 1337 Views
Last post by StupidS80
- 10 Replies
- 4938 Views
Last post by dcm0123
- 1034 Views
Last post by FuddleyPJones
- 11 Replies
- 1945 Views
Last post by plumsmooth
