camshaft sensor and crankshaft sensor question
This topic is in the MVS Volvo Repair Database » Angle Gear Fix - AWD Volvo 2001-2006 S60 / S80 / V70 / V70 XC/XC70 / XC90
the_brain3000
Year and Model: 2002 S60 2.4T AWD
Post by the_brain3000 »
hi,
even since i got the check engine light my 2002 Volvo s60 2.4T AWD i've noticed a pretty significant increase in fuel consumption.
the check engine light turned out to be a P0014(camshaft sensor) and P0016(crankshaft sensor).
what exactly do the camshaft sensor and crankshaft sensor do?
also, how hard is it to get to them and replace?
JDS60R
Been thanked: 3 times
Post by JDS60R »
They monitor crankshaft and camshaft rpm and location by use of hall effect sensor, positioned closely to a tone ring.
They are easy to change. It's rare that they both went at the same time. If so check wiring and fuses first.
Retired
the_brain3000
some weeks ago i had alternator problems and when the battery was drained the indicators were all going crazy, i suppose all electrical things.
after i changed the alternator i got these codes.
how will these sensors affect the car? i don't see any change apart from the fuel consumption that seems higher.
pkc303
Year and Model: 1995 T-5R Yellow
Post by pkc303 »
I'd check all your alternator connections, especially the ground. Then clear the codes and see what you have.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
clear the codes first, and see which one if any returns.
