hi,
even since i got the check engine light my 2002 Volvo s60 2.4T AWD i've noticed a pretty significant increase in fuel consumption.
the check engine light turned out to be a P0014(camshaft sensor) and P0016(crankshaft sensor).
what exactly do the camshaft sensor and crankshaft sensor do?
also, how hard is it to get to them and replace?
camshaft sensor and crankshaft sensor question
Angle Gear Fix - AWD Volvo 2001-2006 S60 / S80 / V70 / V70 XC/XC70 / XC90
the_brain3000
- Year and Model: 2002 S60 2.4T AWD
JDS60R
- Been thanked: 3 times
They monitor crankshaft and camshaft rpm and location by use of hall effect sensor, positioned closely to a tone ring.
They are easy to change. It's rare that they both went at the same time. If so check wiring and fuses first.
Retired
the_brain3000
some weeks ago i had alternator problems and when the battery was drained the indicators were all going crazy, i suppose all electrical things.
after i changed the alternator i got these codes.
how will these sensors affect the car? i don't see any change apart from the fuel consumption that seems higher.
- pkc303
- Year and Model: 1995 T-5R Yellow
- Has thanked: 1 time
I'd check all your alternator connections, especially the ground. Then clear the codes and see what you have.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- 1656 Views
Last post by cn90
- 1109 Views
Last post by ducttapeandzipties
