Creaks from suspension/steering(?) when turning @ low speeds
- Year and Model: Many Volvos
- Been thanked: 76 times
It may or may not fix your problem but start with cheap and easy and smear some axle grease on the plastic steering stops. They are the plastic tabs on the side of your lower control arms. I have some Mercruiser water resistant grease that I use since they are totally exposed to the elements but just about anything will work for a year or so.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
There are at least two other possibilities if greasing the steering stops does not work. First there is a rubber boot where the steering column goes through the floor. Around it is a plastic ring, with a slit on one side so that it can be expanded and removed from the column. Remove same and clean, regrease and reinstall. There is a detailed, step-by-step post on this forum on how to do it.
A more problematic issue (read $$$) could be a split rubber boot for one or both of your cv joints requiring regreasing and replacement, or, if bad enough, you may need to replace the axle/axles.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
That sounds very much like spring seats based on your latest description. Bounce the fenders, with the hood up, and look for vertical travel at the inverted castle washer at the top of the strut mounts. There will be travel but it will be slight.
It could also be bad sway bar end links. The bonus is that that is the cheapest solution if that is the problem.
,,,Lee
,,,Lee
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
To add to what Lee said, your spring seats should not twist around in place, either by hand or with a wrench taken to the top nut. That will make a lot of clunking at slow speeds.
'98 S70 T5
2016 Chevy Cruze Premier
+1 for the spring seat and the sway bar links.
I just changed the spring seat on the passenger side and it took away some of the clunk and then changed the sway bar links and that took away all of the clunk.
1998 volvo v70 non-turbo 140,000
I go to the junkyard to practice future repairs.
Free2drive!
- Year and Model: 2007 XC90
If you turn your wheel on full lock and switch off the motor. You can see the swaybar links if the small rubber boots are torn spray a little wd40 on the joints. Drive round a parking lock, if the sound has gone you'll know it's the drop links.
Honestly if they are original they will be worn anyway as they don't last very long.
Matt
Matt
- 11 Replies
- 836 Views
- 9 Replies
- 4851 Views
Last post by theWIFES_S70
- 831 Views
Last post by Ozark Lee
- 13 Replies
- 2282 Views
Last post by drmegadan
- 643 Views
Last post by heleads
