Hi guys,
I have Volvo V70 2004 with 76k miles on it and I noticed little smoke coming out of an oil dip stick. Looks like I will have to change oil trap and pcv houses. I tried disconnecting my rail fuel line, but so far no success. It is Star Ray fuel line disconnect with 2 push buttons, one on the top and other on the bottom. I pushed, pulled, squeezed , still can't get fuel line to come apart. Do you know if I will need special fuel line disconnect tool ?
Below here are pictures of my problem.
Fuel line disconnet
JDS60R
- Been thanked: 3 times
I will wait for others to chime in but I believe you remove the green tab (pry up and pull out)and then can pull the line out. I am almost sure you have to replace the clip and o ring each time
Retired
You see, I carefully checked my fuel line disconnect against Vidia drawing and I did not find six point screw and and clip as picture suggests. Mine must be a different type. I can depress 2 green rectangular buttons but fuel line stays in. I am stuck at this point and dont want to break anything.
JDS60R
Wish I had more for you.
Best wishes and I will have a drink for you now.
Good on you mate,
John
Take a close look at it - you will figure it regardless of what it was.
Good on you mate,
John
Retired
Thank you JDS60r for your replays. I got fuel line disconnected finally and replaced oil trap. What a nightmare! 2 push button disconnect is a part of fuel rail and stays with it. There is very little room for play with metal tubing and no special tools are necessary. Just squeeze hard 2 green buttons and firmly pull out fuel line. After putting it back I had no gasoline leak around connector.
My oil trap replacement took me 8 hours, sore legs and back, but I enjoyed working on it. My vehicle is running good so far. No smoke coming out of the dip stick. Looks like oil trap was fine, but the engine ports were plugged. Black solid, carbon like substance was blocking them.
elbow and lower port
- pkc303
- Year and Model: 1995 T-5R Yellow
Thank you for the pictures. I'm doing the same thing, and couldn't figure out how to disconnect the fuel rail return line. Mine is exactly like your.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
- 21 Replies
- 8398 Views
Last post by foggydogg
- 1377 Views
Last post by cn90
- 25 Replies
- 20652 Views
Last post by AAXC70
- 3042 Views
Last post by Larry_Dean
- 5547 Views
Last post by precopster
