It appears my ABS module is bad...the TRACS and ABS light come on every so often. My mechanic says that in addition to the part costing $300+, I may need to spend another $200 for "programming". I have no idea what's involved but does that sound right?
Yeah, I know there's a guy on the board that rebuilds these things but I'm wondering about the programming.
Thanks.
ABS module - - needs programming?
TipTopTommyT
- Year and Model: X/C V70 - 1998
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
What? No. Not on a '98. It just needs to have the contacts resoldered, and then both of those lights will go away.
'98 S70 T5
2016 Chevy Cruze Premier
TipTopTommyT
Ok, that's good. I can live with that.jablackburn wrote:What? No. Not on a '98. It just needs to have the contacts resoldered, and then both of those lights will go away.
JRL
- Year and Model: Several
- Been thanked: 16 times
1996-2001 if you can't do soldering yourself...
$100
www.modulemaster.com
Tell your mechanic to take the module and shove it you know where!
He obviously knows nothing about Volvos
$100
TipTopTommyT
Thanks JRL....will the braking system be affected if I drive without the module while waiting for the rebuild? I'm sure the ABS and TRACS lights would light but that's no biggie.
jblackburn
You won't have ABS, but standard brakes, and you also won't have a speedometer.
If you have a GPS unit, most can function as a speedometer while you've got the module out.
'98 S70 T5
TonyMastodon
- Year and Model: 98 V70R
Talk to Matty Moo... I bought a rebuild from him with very fast shipping (3 days) and will answer a lot of your questions on the phone.
Cant go wrong with Matt.
- Has thanked: 2864 times
- Been thanked: 1332 times
^^^ As far as I know, he's currently the least expensive. Haven't heard any complaints.
Matty Moo is the only way to go! Once you install the module make sure you erase the codes and the lights will go off. I stopped at Advance Auto Parts and used their diagnostic code reader to check and erase them for free.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
No! You don't need to clear the codes.
They will clear immediatelly when you go to a test drive after reinstalling the module.(If resoldering was a success).
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 802 Views
Last post by jimmy57
- 1987 Views
Last post by wingspan99
- 11 Replies
- 7202 Views
Last post by Vovoroom
- 391 Views
Last post by RickHaleParker
- 10 Replies
- 6074 Views
Last post by misha
