Suspension pop
IVIUSTANG
Year and Model: 2006 XC70
Been thanked: 4 times
Suspension pop
Post by IVIUSTANG »
Hey guys,
The symptoms are: pop or two pops that can be heard within the car better than outside when at low speed driving or reversing while turning left; it also sometimes does it when I turn right immediatly after turning left. The only ball joints left on this car that are original are my control arms and inner tie rods.
I am chasing a mystery front end pop from my car. I have changed all my tie rod ends and endlinks as well as checked my control arms for any play. I did notice that my bushings on my sway bar are shot. I also had another mechanic friend look at the car and he thought the suspension was very tight and couldn't give me a diagnosis. Two mechanics and one mechanicly inclined person(myself) can't get any abnormal movement out of the tire.
At this point should I order inner tie rods or what do you all think, take the cheaper route first?
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
C@lvin
Year and Model:
Post by C@lvin »
I am having the exact same symptom and assumed it must be an outer tie rod or sway bar end link. Though, like you there isn't anything that's obviously loose (yet). The inner tie rod had not occured to me. Mine is quite loud inside the car and comes from the front passenger side. If I figure mine out first, I'll let you know......
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
pablotar
Year and Model: v70 1998
Post by pablotar »
Sway bar links. they make a noise that seems to come from somewhere else.
I changed them and bad noises went away.
Just sayin'.
1998 volvo v70 non-turbo 140,000
I go to the junkyard to practice future repairs.
IVIUSTANG
Post by IVIUSTANG »
I changed my endlinks and tie rod ends so it can't be those as the sound is identical to before the installation of those parts.
- Jesse
jonesy850boosted
Year and Model: 1994 850 Turbo Wagon
Post by jonesy850boosted »
Mine is doing the exact same thing. I replaced the strut mounts and spring seats - Noise didn't go away. I let me know if the inner tie rods fix it.
marginal
Year and Model: V70 D5 2003
Post by marginal »
Isn't it the limiter (or whatever it is called there) that touches when you go to the left or right extremes?
Mine used to do that, I applied some grease on them, no more pops heard since then ...
IVIUSTANG
Post by IVIUSTANG »
marginal wrote:Isn't it the limiter (or whatever it is called there) that touches when you go to the left or right extremes?
It isn't in this case, it only takes a slight turn to get the pop. I also greased the stops as well, and fixed my strut from rubbing my brake lines on corners.
- Jesse
C@lvin
Year and Model:
Post by C@lvin »
What is the "limiter"? Got a picture of it? I'm ready with the grease - just need to know where to apply it :-) Mine seems to pop at a more severe turn but maybe not all the way to the "limit" as it were.
Calvin
98 S70
00 V70
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
On the front of the axles are a plastic tab. That's what you want to grease.
My Saab always made a similar noise on sharp turns, but I never did bother to find out what it was. I think you guys are right on the right track the inner tie rods, though.
'98 S70 T5
2016 Chevy Cruze Premier
C@lvin
Year and Model:
Post by C@lvin »
hmmmm....
Justin, can you point out the location of "front" and "plastic tab" in this picture?
Thanks!
Passenger Side Axle
Passenger Side Axle
Right Axle.jpg (107.05 KiB) Viewed 1826 times
Calvin
98 S70
00 V70
