Boost level after fitting MBC 855 T-5
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
Locked
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
Anyone suggest a suitable Boost level after fitting a Manual Boost Controller on my 855 T-5? Without setting anything just taking the MBC out of it's box fitting it I now have 14-15 PSI boost on Eco mode, unfortunately I can only test at motorway speeds upto 70mph so the stock boost needle isn't going full swing as it's been suggested
Next weekend I've got some track time after a full brake refit [This thing is so heavy on brakes 3rd set of pads 2nd set of discs since March]
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
charly.. do you know what your remap is set at ? you should be able to run 15 safely with a good remap.
1996 Platinum Edition
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
I'm consolidating MBC topics. Please use this MBC topic, thanks.
Also -> Amazon link
Locked
